80 amp ignition fuse holder broken
Hey, been a while since I have posted. But here it goes
In trying to unblolt the fuse from the fuse holder (i did lower it out of the fuse box) The plastic bit that held the bolts stripped. So the fuse holder is useless. Is there a decent place to replace this or does anybody have a recommendation for an aftermarket 80 amp fuse holder and or breaker setup.
85 Toyota Pickup 22r
I would bypass it, and buy a maxi fuse holder and 80 amp maxi fuse. https://www.delcity.net/store/Maxi-F...20group%20%231.
either that, or rob the holder and fuse from a wrecking yard or parts truck.
Have a look at 'ANS' type fuses and holders. They come in ratings of 50, 60, 80 amps and higher. You can get a nifty little fuse holder for them too. They're about 2" long and about 3/8" wide and 3/16" thick. I used them to fuse the alternator and after the battery disconnect switch for all loads (not the starter) on my 83.
buckz6319
Mar 15, 2016 01:54 PM
alva22re
Feb 20, 2016 04:21 PM
