Brake line size? 2nd gen 4runner
Is it 3/16"? Just want to confirm that it's right. From searching part stores with my vehicle model this is what I come up with but I find it odd that it's in imperial and not metric.
90' 22re
90' 22re
MAKE SURE THAT YOU USE M10x1.0 INVERTED FLARE NUTS!!! There is a standard nut (not sure of the size) that WILL thread into M10x1.0 threads but WILL NOT work - you can hardly tell the difference between the two. There is also a M10x1.0 bubble flare nut that looks similar but WILL NOT work either. Napa does have brakelines up to 72" that are pre-flared. Use your original lines as a template to bend new ones and replace a section. I know at Napa they are labeled "JAPANESE" and I'm fairly certain that they don't even have the flarenut sizes on the label.
FS[PacSouthWest]: Parting out 1986 TOYOTA 4RUNNER 1ST GEN.
4x4-runner
Apr 23, 2018 09:35 AM
layifioren
Nov 14, 2017 03:37 PM
