General Electrical & Lighting Related Topics Ask here for electrical, wiring, and lighting info for your rig that could apply to all years
85 4Runner Power Window Headace
Old May 21, 2016 | 11:29 AM
808nickh's Avatar
OK guys I have a 85 toyota 4runner sr5 and I have been battling a weird issue with my passenger side power window on my 4runner. I can get the window to roll down from both the driver and passenger side switch but not roll up. Driver side window works fine goes up and down with no problem.
I have been doing a lot of research to find someone that has had a similar problem but I have not made it to far. So far I have bypassed my power window relay using the 4crawler trick with no luck, so relay is good. I have manually tested the regulator with a 12v batt and I can get the window to roll up and down. Also I have disassembled both switches and cleaned the crap out of them with no luck. Now I have resorted to pulling the door harness and testing for any bad wires.
I have noticed on some of the newer model 4runners and pickups the master switch is a little different it also has door lock switches were mine does not. It is simply 2 windows up and down. Also reading some of the newer model vehicles have a black control box under the dash were mine does not either, unless I cant find it.
The odd thing is, is that I am getting 12v when i press the up button on the switch on both the driver and passenger switch but i get nothing from the regulator, its like I am having a ground issue somewhere. I have the wiring diagram laid out on my work bench and I have been trying to make my way through it but at this point I'm lost.
If anyone can shed some light on this or has had a similar issue at this point anything will help.
Old May 22, 2016 | 12:53 AM
wyoming9's Avatar
Your getting 12 VDC read with a Meter ??
What voltage do you get at the motor ??
The track and the window regulator are lubed so you have no added resistance ??
The right window switch has two sets of contacts which you should see on your schematics.
When the switch is in neutral the contacts allow the master switch to control the window .
When the right window switch is used it uses the other set of contacts .
if either of these are not making good contact windows don`t work.
A window motor getting old and tired might not work through the harness but seem to work fine when voltage is applied direct to the motor
** in the past I have had some that only work with the engine running
Old May 22, 2016 | 05:15 PM
808nickh's Avatar
Your getting 12 VDC read with a Meter ?? Yes I an getting 12vdc at the regulator
What voltage do you get at the motor ?? its in the ballpark of 12v +/- 1v I can get specifics here in a bit
The track and the window regulator are lubed so you have no added resistance ?? Yes the window moves perfectly using 12v supply directly to the regulator
Im also getting 12v to the regulator using the master switch in the up position. Ill get some pics too so you can see what I'm working with.
Old May 22, 2016 | 10:14 PM
wyoming9's Avatar
If your getting voltage at the regulator there is a short
The regulator is what the electric motor attaches to
it is also possible there is a broken wire in the harness coming from the right door.
The ground for the windows is on the left door post.
Old May 23, 2016 | 12:08 PM
808nickh's Avatar
Ill have to check the ground I have some time today I'm going to get back out there and take another look
Old May 23, 2016 | 12:31 PM
808nickh's Avatar
So here is a picture of my passenger door harness pulled out of the door, I pulled it out to get a good look at the wires to make sure there was nothing funny going on. With the test leads hooked up like this I have nothing on my meter.
When I run the my leads to ground off the regulator plug I get 12.13 in the down position.
And I get 12.12 in the up position
Also is this the ground for both windows or just the driver side?
Attached Thumbnails 85 4Runner Power Window Headace-img_1790-1-.jpg   85 4Runner Power Window Headace-img_1786.jpg   85 4Runner Power Window Headace-img_1791-1-.jpg   85 4Runner Power Window Headace-img_1792-1-.jpg   85 4Runner Power Window Headace-img_1788.jpg
Old May 23, 2016 | 12:41 PM
808nickh's Avatar
This is what my master switch looks like
Old May 23, 2016 | 12:50 PM
wyoming9's Avatar
Both windows they ground through the Master switch
Because the polarity changes to reverse the motor
The thing is you have no idea what might have been done before you had the truck .
Your lock switch is in the closed position ?? not that it is open
Old May 23, 2016 | 12:54 PM
808nickh's Avatar
Do I have a lock switch? the only lock switch I can think of is for the rear window, if the lock switch was on wouldn't the window do nothing?
As of right now it goes down perfectly just not up.
Whats weird is it was a one day it worked and the next day it didn't kinda thing, not quite sure whats going on.
Old May 23, 2016 | 12:57 PM
808nickh's Avatar
My next question is if both windows ground through the master switch, why with the master switch disconnected to I have the same meter readings as listed above?
Old May 23, 2016 | 01:12 PM
808nickh's Avatar
Nevermind with the master switch disconnected i get nothing from the regulator I'm pulling the master switch apart now to take a second look at it.
Old May 23, 2016 | 11:12 PM
wyoming9's Avatar
The schematics your using are for the correct year ??
I can now see a big difference between the 85 and 86 prints
kawazx636
Mar 23, 2023 09:37 AM
FinallyOffRoad
Feb 19, 2016 06:29 AM
MBOS4x4
Feb 6, 2016 08:19 AM
FinallyOffRoad
Feb 6, 2016 05:18 AM
