Pre 84 Trucks 1st gen pickups
Wobbly steering just off center
Old Apr 28, 2016 | 10:21 AM
GodwinAustin's Avatar
Hi Everyone just purchased a great running, but rough around the edges '82.
The steering tracks OK, but there is a distinctive wobble in the steering wheel just off center in either direction -kind feels all loosey-goosey/light along with the wobble - once you get farther in the turn the wobble disappears and the steering tightens up.
Any ideas where to start?
Old Apr 28, 2016 | 10:44 AM
highonpottery's Avatar
My instinct would say inspect the pitman arm, steering box and steering coupler for play. Guessing maybe worn pitman arm joint.
Old May 2, 2016 | 07:38 AM
Simian's Avatar
I replaced my tie rod ends and put new tires on and got an alignment and not mine is rock solid straight as an arrow.
Old May 2, 2016 | 11:27 PM
Fastbug's Avatar
i'd try taking a peek at you trunnion bearings, my buddy just had to replace his and it caused some serious wobble.
Old May 10, 2016 | 07:11 PM
moroza's Avatar
It sounds like a weak steering stabilizer combined with a lot of play in the steerbox. Put the front axle on jackstands and start wiggling things around; you'll find what's loose pretty quick.
Old May 11, 2016 | 09:50 AM
enigmaT120's Avatar
Sometimes it's good to have somebody sit in the truck and move the steering wheel side to side, while you watch the different moving components to see where there is any visible play.
40vern
Apr 12, 2016 05:36 PM
jeffraaa
Apr 6, 2016 06:24 PM
TheHaak
Apr 5, 2016 01:42 PM
shredwhiteandblue
Mar 30, 2016 06:25 PM
