What size tubing to use?
Old Mar 25, 2004 | 08:30 AM
ravencr's Avatar
Hey guys,
I'm wanting to buy some tubing to use for two primary purposes, and I'd like to get by with one 20ft length to save some money. Here's what I'm wanting to use it for:
1) Rear suspension links
2) Skid plate reinforcements
I need something that I can easily use either spidertrax or pro-werks weld in tube adapters for the suspension links, and something that will not dent under most circumstances for the rear suspension links. What do most people use for those? Do they use 3/16" or 1/4" thickness, and what diameter is most common?
Chris
Old Mar 25, 2004 | 09:23 AM
loosehead's Avatar
Chris-
I'd say go with 1 1/4" DOM tube with 3/16th inch wall-thickness. This has an I.D. of 7/8", which would let you use the weld-in threaded bungs easily (3/4" threads for 3/4" rod ends).
This would probably be overkill for skidplate reinforcing, though. I would use smaller for this, say 3/4" tube...
Old Mar 25, 2004 | 10:39 AM
crash's Avatar
I agree with loosehead, but I would suggest chromo for the lowers, thats how mine is being setup
Old Mar 25, 2004 | 02:47 PM
ravencr's Avatar
Originally Posted by loosehead
Chris-
I'm only going to use the tubing for the skid plates in a few places, and you might be right about being overkill for that. So is that a pretty common size then for suspension linkages?
Chris
Old Mar 25, 2004 | 02:48 PM
ravencr's Avatar
Where do you guys recommend getting chromoly tubing from?
Chris
Old Mar 25, 2004 | 04:29 PM
Cebby's Avatar
Isn't chromo typically thinner wall - ie. dent easily??
Old Mar 25, 2004 | 04:36 PM
ravencr's Avatar
I have no idea, but I sure would like to know the differences between mild steel and chromoly before I make the plunge.
Chris
Old Mar 26, 2004 | 06:20 AM
Shane's Avatar
The fact that it's chromoly has no connection to how thick the wall is. You can get thin wall, thick wall, solid, etc... Heck, a lot of gun barrels these days are chromoly.
Old Mar 26, 2004 | 06:21 AM
crawler#976's Avatar
DOM guide-
http://www.copperweld.com/pdfs/DOMSpecs.pdf
from mild steel to alloy steel- it shows yeild strengths, etc.
later
Old Mar 26, 2004 | 03:24 PM
ravencr's Avatar
Where can I buy chromoly tubing?
Chris
old87yota
Sep 9, 2015 12:39 PM
Gravel Maker
RuffStuff
Sep 8, 2015 05:46 AM
gp66
Sep 7, 2015 08:29 AM
BigMike
Marlin Crawler
Sep 3, 2015 07:49 PM
dguzzi
Sep 3, 2015 08:48 AM
