Head Ground Bolt Brokem
Old Mar 11, 2016 | 04:58 PM
Gamma_Hugo's Avatar
So today I was changing out my spark plugs and I read in a thread that says that changing out an old ground wire my help with a slight misfire I am having. so I decided to change it and the bolt connected to the head broke off. Any suggestions on how to fix it or if there is another spot on the head where i can bolt on the new Ground?
Thanks in advanced
Attached Thumbnails Head Ground Bolt Brokem-img_20160311_154754.jpg   Head Ground Bolt Brokem-img_20160311_173641.jpg   Head Ground Bolt Brokem-img_20160311_173718.jpg
Old Mar 11, 2016 | 05:05 PM
millball's Avatar
You can bolt up the ground just about anywhere on the head.
Grounding to the valve cover is probably the worst choice.
Go directly to the head or block.
Old Mar 11, 2016 | 08:47 PM
Gamma_Hugo's Avatar
for sures, just wasn't too sure if i could bolt it up on any spot on the engine (with the exclusion of the valve cover) or if it had to be in the original spot. looks pretty good.
Johnboy80
11
Jul 14, 2016 03:29 PM
panheaddav
Mar 20, 2016 05:10 PM
parker247
Mar 9, 2016 05:06 PM
Yont283
Mar 9, 2016 04:33 AM
Vernsyota
Mar 7, 2016 04:41 PM
