Are rear shocks different sizes? Mine are.
I replaced my rear shocks today so I could hopefully get rid of the right rear sag. Well, I still have the sag. It's about an inch difference and what's crazy is I decided to measure my old shocks and they are different in size. I extended them and they aren't even.
Any thoughts.
Any thoughts.
Shocks should be the same length on the rear. That being said the sag is your spring not the shock. Shocks do not lift or raise the truck they only dampen the recoil of the springs. Shock travel is only related to spring traveling in so much as you need enough shock travel to match your spring travel.
Thanks for helping me understand that. Because I put new shocks on today and I have about an inch lower sag on my rear right still. Guess it's shackle time or new leaf springs.
Should I check anything else?
If your springs are good the number from the axle to the frame will be the same. If the spring is worn out then it won't be lifting the frame off the axle enough and the frame will be closer to the axle on the lower side. If the spring is good the spring will push the frame up the same amount even if it is twisted but to the eye the one side will look lower as the frame is bent.
Thanks bud!
I'm lucky because my dad is a cabinet maker and has owned his own business for the past 25 years. I grew up in his shop and eventually became a machinist so I do all his metal work and he lets me use all his equipment for wood work that he taught me how to do.
Originally Posted by Nippon_surf
How would you tell the wear in your springs? I'm upgrading rear leafs soon, but curious if there was a way to know the wear of oem.
Originally Posted by Yotard
Thanks bud!
tj884Rdlx
Feb 5, 2016 08:07 AM
localfiremedic
Jan 31, 2016 07:16 AM
