my blinkers and hazards arent working
Old Jan 31, 2016 | 03:07 PM
kauaiaxel's Avatar
Recently got into a project its an 86 22r SAS and there is no response at all when the turn signal switch is on. Nothing on the lights nothing on the dash also the hazards are unresponsiva also. Could it be the switch? A bad fuse? Flasher relay? I am pretty stumped on this, can anyone help me out?
Old Jan 31, 2016 | 03:46 PM
scope103's Avatar
Yes. No (you could have a blown fuse, but that's still a "Good" fuse because it did what it was supposed to). No (you don't have a flasher relay).
Given that you lost both the turn signals and the hazards, I would replace the Turn Signal Flasher before I even whipped out my multimeter. Here's the test for a flasher http://web.archive.org/web/201102052.../4lighting.pdf, but Autozone has them for $13, so it's almost not worth the time to test the old one.
Old Jan 31, 2016 | 04:01 PM
kauaiaxel's Avatar
Thanks scope103 i will give that a shot as soon as i can
Old Feb 2, 2016 | 02:15 PM
kauaiaxel's Avatar
I changed the flasher and cleaned some connections and it worked! All blinkers and hazards working now. Thanks
Dexter350k
May 19, 2021 10:31 AM
RustyTKO
Jan 31, 2016 04:10 PM
Mattsteele
Texas
Jan 30, 2016 11:26 PM
yotajakes
Jan 30, 2016 07:49 AM
808_4runner
Jan 26, 2016 08:07 PM
