Pre 84 Trucks 1st gen pickups
4wd indicator light
Old Jan 22, 2016 | 09:04 AM
CAdot's Avatar
4wd indicator light
Old Jan 22, 2016 | 11:12 AM
mwisham's Avatar
I would think the indicator switch for four wheel drive would be on the transfer case, not the transmission. Switch on trans is probably for reverse lights.
Old Jan 22, 2016 | 11:59 AM
CAdot's Avatar
Old Apr 19, 2016 | 02:23 AM
CAdot's Avatar
Old Apr 25, 2016 | 12:41 AM
msane99's Avatar
switch should have two studs on it and wires slide over round studs. will take picture for you in morning. but should have 2 wires. i have both setups will crawl under and check them out when sun comes up..
Old Apr 28, 2016 | 08:02 AM
CAdot's Avatar
Old Apr 29, 2016 | 03:05 PM
msane99's Avatar
Ok 80 has 2 wires one green one white with black stripe. W56 has one green wire. Do you have old transfer case? Looks like sending unit is threaded the same.
Old Apr 29, 2016 | 03:08 PM
msane99's Avatar
80 uses same plugs that are one marker/blinker lights. Think white with black is common.
Old Apr 30, 2016 | 02:46 PM
GodwinAustin's Avatar
i have the opposite problem here where the harness at the transfer case was disconnected, plugged it back in - now the light stays on all the time and won't go off, is there a relay as part of this system that could be the problem - the transfer case was supposedly rebuilt too so that could have something to do with it...
Marc
10
Dec 28, 2015 01:08 PM
83str8
Dec 26, 2015 09:15 AM
9322rerunner
Dec 15, 2015 10:14 PM
jhsantacruz63
Nov 7, 2015 07:35 PM
Yotahuntingrig93
Nov 1, 2015 10:11 AM
