Need links for panel removal
I'm not having much luck with the search engine finding info on removing the AC slider panel removal. '93 Truck with AC.
I need to know how to remove the flat knobs off of the levers?
How to remove the plastic panel after the knobs are off?
Thank you.
Thank you.
The knobs pull straight off; friction fit.
The panel is a click-fit, so just get a tool in one of the slots and pull carefully.
With all things rubber and plastic, they get brittle with age. Warming things up GREATLY reduces your risk of an accident. Wait for a warm day, use a hair dryer, or a heat gun (a heat gun can melt stuff; put your hand on the part you're warming. If too hot for your fingers, back off).
Everything came off without too much trouble. I warmed the panel with a heat gun and all but the dead center,at 6 o'clock latch came right out. That last one kicked my butt for 20 minutes until I could free it and not brake it off.
I have other questions I will post in topics.
Thanks again.
Thanks again.
erock13
Mar 20, 2016 08:36 PM
TURBOrunnerNM
Jan 13, 2016 09:23 AM
