General Electrical & Lighting Related Topics Ask here for electrical, wiring, and lighting info for your rig that could apply to all years
reverse light switch keeps frying
Old Jan 7, 2016 | 01:35 PM
blackmajic's Avatar
My 93 pickup keeps frying the reverse light switch. Gone through two switches and I'm not about to buy a third one until I figure this out. The switches last about 2-3 weeks then seem to melt between the terminals. Lights work fine with a jumper wire in the switch plug. I have not left the jumper wire in any longer than one minute, jumper does not seem to get hot. Harness between tail lights and cab look fine. All fuses are good. Bulbs good. Plug is clean. Only other electrical issue with the truck is the vehicle speed sensor does not work but sometimes the speedometer jumps all over the board, rolling or not. I'm not sure if the reverse light switch and the vss issues are related. Going to open up the harness between the Trans and the engine bay on sunday. Any input or ideas would be appreciated. Thanks!
Old Jan 7, 2016 | 02:16 PM
RAD4Runner's Avatar
Most likely cause would be a short on the side going to the back-up lights. That harness, at least on my first-gen 4runner, is poorly secured and vibrates against the tranny.
Next likely IMHO contamination from oil and dirt down there.
Old Jan 7, 2016 | 03:41 PM
wyoming9's Avatar
Red face
If it is a short why does the circuit protection open before the switch melts??
I guess the Op did not like my questions on his first thread.
Old Jan 7, 2016 | 05:25 PM
dropzone's Avatar
Fossilized
Running any extra lights off that circuit?
Old Jan 7, 2016 | 05:43 PM
RAD4Runner's Avatar
In could be "mild"short", some leakage to ground, not enough to blow the fuse, OR overload condition like Robb mentions above - Enough to overload the switch but not enough to blow the fuse.
Old Jan 7, 2016 | 11:26 PM
wyoming9's Avatar
Red face
Could very well be poor quality switches .
Then running extra load should draw more current causing things to open.
Then the OP`s idea of a melted switch and mine may be slightly different.
Old Jan 8, 2016 | 09:30 AM
blackmajic's Avatar
There is a utility trailer light kit wired into the tail lights. The first switch blew before the instal and is not spliced into the reverse circut. I'm ripping the harness open on Sunday
Old Jan 8, 2016 | 09:56 AM
blackmajic's Avatar
There replacement switches that have blown are Taiwan SMP intermotor from NAPA. I had to return the first one I bought because the threads weren't cut properly
Here's a pic of the (melted) switch. Not totaly melted but bubbled plastic out the back.
Old Jan 8, 2016 | 09:58 AM
blackmajic's Avatar
The switches are of poor quality. Good point!
Old Jan 8, 2016 | 01:04 PM
blackmajic's Avatar
Seems to be a combination of a bad switch and shorting out. Looks to me like the switches leak gear oil through the terminal posts, in return end up shorting out the switch. Does that sound logical? I'll be getting a switch from toyota soon and post an update. Thanks everyone for the imput!
Old Jan 8, 2016 | 04:58 PM
wyoming9's Avatar
Red face
If that is indeed the case I would be shopping for a transfer case as well.
For gear oil to be conductive it would need lots of metal particles in suspension.
I will be looking forward to how this works for you
Old Jan 8, 2016 | 06:05 PM
RAD4Runner's Avatar
Yes, combination of contaminants, including dust could become conductive like I said above.
shisha1999
Mar 3, 2016 07:28 PM
-City Slicker
Jan 5, 2016 06:54 AM
Woslagerj
12
Oct 31, 2015 04:41 AM
yotapwru
Washington
Oct 22, 2015 09:08 AM
Toyowner_
Oct 16, 2015 01:33 PM
