What to do with the radiator- 350 Conversion options?
I have a 83 Toyota and am putting a 350 in it what is the best option for the radiator placement? What radiator works best... Pull or push fans which works better... Thanks first v8 swap
you will probably find your answer here (it might take a little effort but I am pretty sure it has been covered)
https://www.yotatech.com/forums/f158/
It really depends on just what your end use is going to be.
Will this be a Impressive Mall Crawler that sees the far ends of the parking lot??
Off road vehicle that could be hours from help ??
These things play an important part in figuring out just which materials to use.
Aluminum radiator in stock position....fan shroud.....centrifugal fan clutch. If you go electric fans then you take your chances. You risk overheating followed by a headgasket job.
FS[SouthEast]: 86-95 ifs parts
94yotaky
9
Feb 22, 2016 02:39 PM
