Michigan Rust!! :(
Old Oct 29, 2015 | 12:31 PM
92truckowner's Avatar
Michigan Rust!! :(
I live in Michigan where every vehicle after 5-6 years rusts from too much road salt.
I just bought a 2000 4runner thats in good shape (mostly). The rocker panels are suffering though and I want to do something before the cancer spreads.
I got quoted by a body shop at $1000 per side!! There has to be a cheaper solution. I've already considered cutting out the bad metal to weld in new but I'm afraid there isn't enough panel left to support this job.
I've also considered cutting away 95% of the rocker panels and then having the good metal refinished and just run without any rockers, I don't know if this is a good idea. I just want to save my vehicle, It only has 126k on it, its still a baby!
Old Oct 29, 2015 | 04:59 PM
aowRS's Avatar
Pics?
Andreas
Old Oct 29, 2015 | 11:30 PM
wyoming9's Avatar
Red face
It is a constant battle every spring .
If you can weld do what ever you like.
Remove the rocker panels and replace with custom made sliders that do double duty.
Old Oct 31, 2015 | 05:52 AM
I cant weld unfortunately.
I also just got laid off for the winter so my budget is pretty low. I do like the custom sliders idea though. Any suggestions on where to go for that? The nearest off-road shop is a 3 hour drive from me.
Old Oct 31, 2015 | 05:53 AM
Ill get some pics today too, its pretty bad.
Old Nov 1, 2015 | 04:38 AM
Old Nov 1, 2015 | 05:07 AM
aowRS's Avatar
How is the frame? If it's solid, I'd discuss the rocker panel repairs with a body shop.
If the frame is holed, put some Gorilla Tape over the rockers and just drive...
Andreas
Old Nov 1, 2015 | 07:14 AM
The frame has rust but no holes. Its still solid.
And I got quoted $1000 a side at a body shop for rockers. Not spending that much on rockers.
Old Nov 1, 2015 | 10:34 PM
wyoming9's Avatar
Red face
Depends just how picky you are
you can pop rivet pieces on.
get fiberglass mesh and patch them then do the finish work.
$1000.00 a side sure sounds like the body shop did not want the job.
Old Nov 2, 2015 | 06:51 AM
Im really leaning toward just cutting them off and coating the good metal with a rust inhibitor to try to get thru the winter until I am steadily employed again. Then I can go back and do custom rock sliders or stock rockers if I can find them.
Anyone posting have any body work experience? Im wondering what a more reasonable quote might be, just a ballpark figure.
Old Nov 7, 2015 | 04:19 PM
ThorInc's Avatar
Avoid parking on grass or any surface, leaves for example, that will retain moisture. That will for sure speed up the rot on the body and the frame.
Old Nov 10, 2015 | 08:22 AM
Bandit Runner's Avatar
I feel your pain fellow Michigander. I have some rust on my rockers as well.
Old Nov 16, 2015 | 03:34 PM
Arnezie's Avatar
Wow my Michigan 2000 is no where near as bad. But then again they don't put near the salt down on the roads as they do up your way.
Jamie4runner2000
Jun 20, 2016 09:13 AM
coryc85
Dec 5, 2015 08:42 AM
fastkevman
Oct 31, 2015 08:59 AM
bobjohnson2121
Sep 17, 2015 08:07 AM
smithoman
Aug 24, 2015 08:19 AM
