So i'm getting ready to install the water pump on the timing chain cover. And I found 3 studs, I don't see this in the manual. Did someone change this or do i need to replace it whit the right bolts.
I can't find were i read it was ok to use copper spray gasket to coat paper gaskets and to use ultra gray when i install them. So is this ok? I have 2 other i can use if i screwed it up.
