Sponsored by: CARiD
Upper ball joint troubles
Old Oct 5, 2015 | 08:41 PM
BIGDEERHUNTER's Avatar
I recently had a upper ball joint separation while driving 55 mph causing the entire passenger wheel to snap off. Pretty scary stuff. I installed new tie rod, upper and lower ball joints on both sides. The dust boot on the Master PRO Upper has torn. Only been a week and this was the side that broke originally. Should I go try to find a new cover or buy a new joint for the cover or could there be a underlying problem. It is a spacer lifted 1997 extended cab 4x4. Don't know if I would survive another crash.
Old Oct 6, 2015 | 07:23 AM
wyoming9's Avatar
Red face
We have pretty much found using any Ball Joints but those from Toyota on Tacoma`s to be a bad idea
You were lucky most often it is the bottom that fails
How many miles .
If your Ball joint spacers were installed incorrect it could be part of the problem
A few threads on here about what goes wrong !!
Old Oct 6, 2015 | 03:09 PM
I will probably buy some Toyota ball joints. My spacer is in the top of the strut tower.
aowRS
Sep 13, 2017 08:22 AM
gyroscope7
Sep 21, 2015 04:55 AM
elaketiger
Sep 14, 2015 09:58 AM
Dparr2ndgen
Sep 8, 2015 01:06 PM
zz_denis
Sep 6, 2015 03:43 PM
