AC Belt Needed??
Old Sep 29, 2015 | 07:36 AM
EVars's Avatar
AC Belt Needed??
'85 22RE
I just replaced my timing chain, and as I'm putting belts back on, I had this thought that maybe I don't need to put the AC belt back on. My AC doesn't work and it actually sounds like a bearing on the AC pulley is going out. So my questions is: Do I have to put the AC belt back on? Does the AC belt help move other parts, will not putting it on mess on timing or anything? Will not installing my AC belt improve gas mileage?
Old Sep 29, 2015 | 09:55 AM
mwisham's Avatar
If the belt only goes from the crank pulley to the a/c compressor, you do not have to put it back on. I doubt you will see any difference in fuel mileage though.
Old Sep 29, 2015 | 10:07 AM
EVars's Avatar
Thanks for the repl, mwisham. I'm going to leave it off until I have time to address the AC pump.
Old Sep 29, 2015 | 10:49 AM
highonpottery's Avatar
leave it off. i did the same thing 5yrs ago. haven't noticed any change in MPGs
Old Sep 29, 2015 | 02:06 PM
Terrys87's Avatar
You can leave the belt off. I have seen two styles of pulley but the bearing can be swapped out https://www.yotatech.com/forums/f199...l#post51649322 when you get to that point.
bigjstang
Jun 2, 2025 03:56 PM
TURBOrunnerNM
Jul 22, 2015 11:01 AM
bryan34w
Jul 6, 2015 05:53 PM
Jnkml
Jul 6, 2015 01:20 PM
mickyd9990
Jul 6, 2015 09:01 AM
