98 Toyota 4runner problems
Hello I have a 98 Toyota 4runner 6 cylinder 4x2 . I was jumping someone at the store cables connected to my battery they accidentally touched the ends of the cable they was holding sparks and my runner died. No spark and no power to fuel pump. Replaced ECM, and fuel pump, fully removed the vip security system no change, it still turns over and that's all. I don't know what else to do, or change. Something happened right after the cables touched I seen it spark when they touched, I looked back at my runner and it died. All fuses have been checked and relays they are all good. Thanks for the help
Time to break out the meter !!!
Just how did you check the relays??
You tested all the fuses with your meter??
Burnt wire some place.
So just how did you figure out the ECM and Fuel Pump were bad??
When you had no voltage to the fuel pump.
You went with new parts out of the box??
Just why did you do touch your positive cable to your negative cable??
Something is open someplace you just have not found it yet
FS[MidWest]: 1995 4Runner 5vz 4x4
vasinvictor
Jan 20, 2016 12:39 PM
JaredL
Jun 16, 2015 04:47 PM
