Blinker issue odd citation
Old Aug 19, 2015 | 02:59 PM
89Yota4x4RatTruck's Avatar
I have a 1989 Toyota pickup 4x4 4cyclinder, when I got the truck a week ago the blinkers didn't work no click no light driving It home from a friends after brake work the blinkers worked but fast blinks (like a light was out) then the next day nothing so I replaced the blinker relay and no luck really need some pointers here guys!
Old Aug 19, 2015 | 11:33 PM
wyoming9's Avatar
Red face
All the turn signal lights work you just have the Hyper flash??
Does this have LED bulbs or lights ?? If this is the case you need a flasher made for the LED lights .
Old Aug 20, 2015 | 12:52 AM
Terrys87's Avatar
Check the sockets and the bulb contacts are clean. The Return wire has needed cleaned or replaced on mine before. Usually a little corrision some where in the assembly.
Old Aug 20, 2015 | 02:37 AM
Regular bulbs no lights at all at this point I've checked all weird and grounds and I am now going to remove the lever and switch from the steering colum
Old Aug 20, 2015 | 10:24 AM
wyoming9's Avatar
Red face
Why does every one take things apart that would be the last thing to look at??
You should check for voltage at the plugs before the lights.
Maybe all the bulbs are burnt out??
Checked that the fuse is tight in the socket??
Checked the fuse is not open??
Do the 4 Way flashers work??
Old Aug 23, 2015 | 04:05 AM
AKHeathen's Avatar
turn the hazards on and off and try again. intermittent stuff like that in my audi would be moisture related, indicating a poor contact.
LosPatosDelSur
23
Mar 12, 2021 03:08 AM
DeathCougar
Apr 1, 2018 11:29 PM
ghostmoney
Jan 28, 2018 11:42 AM
Team420
Dec 30, 2015 01:31 PM
terminator
Jul 27, 2015 07:13 PM
