22RE Cold Air Intake pros v cons Help
Unless you build your own to be a true Cold Air Intake they are most often worse then stock depending what climate you live in.Now if you like to play in the water a real snorkel that pulls air from up around the roof is of help
it's a plastic tube, that has the end bent over slightly, to keep direct airflow from being forced into the tube, and it's connected to the air box beneath the filter... i can't find a picture of it.
FS[GreatLakes]: Toyota collection part out
88sasturbotoy
Jan 30, 2026 01:57 PM
tpd143
Jul 7, 2015 09:06 AM
