Last edit by: IB Advertising
- Toyota Tundra How to Replace Timing Belt and Water Pump<br>Step by step instructions for do-it-yourself repairs.
my computer won't wake up! 06 Tundra 4.7
You forget to connect something.
Could be a simple as the ECM ground loose ground connection .
Maybe you caused a fusible link or fuse to open..
Battery dead ??
Could be any or all of these things
Battery dead ??
I went back through everything.
fusses are all good
relays are all good
when I turn on the key I don't get any computer response (ie no engine light on the dash)
the starter circuit is hot leaving the switch but then goes to the ECM and I lose it there.
I can't tell that I touched anything that would create this problem.
This is the 4th time I have done this job on this truck so I'm not new to it.
never had any problem before.
fusses are all good
relays are all good
JookUpVandetti
7
Sep 10, 2015 08:56 AM
FS[PacNorWest]: Take off Tundra and other Toyota Parts
justdifferentials
Sep 8, 2015 03:13 PM
