Getting rear tailgate window down without power?
Old Apr 30, 2015 | 04:32 PM
toyota884runner's Avatar
Hello, i bought a 1987 4runner and it has no engine. i was wondering if there is a way to get the tailgate window down without power?
any help is appreciated.
Old Apr 30, 2015 | 04:50 PM
millball's Avatar
You can remove the carpet and inspection plate on the inside of the tailgate and disconnect the motor plug. Then, use jumper wires from a battery to lower the window.
You can also remove the motor itself and the window will fall to the bottom of its travel, but removal of the motor is a pain, as I recall.
Running the window down with jumper wires is your best bet.
It might be possible to jumper the motor at the window relay box in the left rear quarter panel, but you'd have to consult the electrical schematics for your truck to figure out what to do.
Old May 1, 2015 | 04:27 AM
wallytoo's Avatar
doesn't need an engine in the vehicle to work, just a connected battery. turn the ignition switch to "on", and use the console switch. or use the tailgate key switch, leaving the ignition switch "off".
the window can be lowered without any power, and it does involve pulling the interior tailgate panel and removing the window motor/gears assembly.
Jun 1, 2021 01:51 PM
Johntom240
7
Jul 13, 2015 12:18 AM
mlavery85
Jul 12, 2015 10:33 AM
mickyd9990
Jul 6, 2015 09:01 AM
coryc85
Jul 6, 2015 04:07 AM
