Vacuum line replacement, silicone or oem?
Buy a couple rolls of the different size vacuum hose you will be good to go.Silicone hose I think is overkill for vacuum lines
Then if you want to spend the extra money go for it.
Silicone won't dry rot on you, but then rubber won't dry rot on you for another decade anyway. It is one way to get a color pop under the hood I spose. What's the cost difference? I stick to rubber.
Never tried the silicone and if you can get it in different colors guess you could use it for easier memory aid for proper connection or dressing up the engine bay. I see so many of these trucks running the orginal hose and still working great. I just grab 3 or 4 foot of part store vacuum line and change it out when I do and no problems.
skoti89
Jul 8, 2015 12:05 AM
