Where do A/C VSV Vacuum Lines Hook Up?
Can someone with factory AC tell me where the vacuum lines from the A/C (Grey) VSV connect?
There is a distributor thing at the back of the plenum (near the firewall and EGR valve) that has one plugged connect, so I am guessing one line hooks there, but I have been unsuccessful in figuring out where the second line hooks up.
Thank you
Thank you
It depends on the engine. The "distributor thing" (the gas filter) is not the intake manifold source; the one for the A/C is a separate, larger port.
http://personal.utulsa.edu/~nathan-b...23vacuumho.pdf
https://www.yotatech.com/forums/f116...-one-c-255881/
What does it look like? What does it do? Where is it found?
Just what are you asking?
Tacoma1313
Aug 17, 2015 05:44 PM
TokyoD23
Jul 12, 2015 06:01 AM
