85 22re aux air valve
have a question about testing the valve. my buddy said to pull the air hose behind it and if the idle goes up its most likely a clogged port. i pulled the hose off and the truck wouldnt idle and if i tried to hold the throttle up it missed. put it back on and ran fine. pulled the hose in front and it idles super low. any way at this point what would be my next step? the problem im having is no fast idle on cold starts.
FSM usually helps but what the hell... here....
if it's doa, don't bother repairing it, just do the later model intake swap: http://www.pirate4x4.com/forum/toyot...take-swap.html
$202 ouch! lol
you can get the entire swap used for that much, or less, and it's much better.
helpful tip: i was able to use the '86 throttle cable, by cutting the very tip off slightly with a die grinder, and screwing on one of the dorman help barrel ends... i think that i had to drill the barrel out very slightly tho.
Got a question regarding my '85 truck with a 22re. It has recently started a really fast idle at cold start up. This lasts for about 20-30 minutes, and once I get up in the mountains it settles down to its normal 800RPM or thereabouts.
My truck appears to have a motor from a 1990 truck in it; judging from the code on the intake and the fuel injectors that were on it. I've had numerous issues getting it to run on the 1985 computer, and along the way have done the following:
- all new vacuum hoses; threw away the metal spaghetti from the 1990 and routed everything straight with new vacuum hoses
- replaced the master cylinder and booster, due to loss of idle under heavy braking
- replaced fuel injectors with '85 model
- replaced the rubber boot coming from the air cleaner to the intake
This truck does not seem to have an aux air unit for warm-up. My '87 had one, and I ended up rebuilding that one, but I don't see one on this engine. Was the '85 model EFI supposed to have one???
The intake swap discussion that I saw was talking about trucks in the 86-90 range. For whatever reason, my 85 does not seem to have one on it that I can find. Perhaps I just need to look closer? On my last Toy, it was underneath the front of the air intake (the front of the air dam or whatever the correct term is for it.) I've had this thing taken down a fair piece, but have yet to see a cold idle air mix box on it?? That's sort of the confusing part.
Did the 85 use this type box, or did it use some other method for the fast idle at startup?
the1998sr5
15
Jul 14, 2020 08:35 PM
Sep 4, 2015 09:27 AM
sojourner567
Jul 16, 2015 08:52 PM
