Swap with tight throttle cable
Old Apr 11, 2015 | 04:23 PM
Oregon'sLoneWolf's Avatar
After my swap I still have an idle problem and think my cable is to blame. I"m using the 3.0.
As you can see in the picture the cable is real tight and I can't figure out how to get the cable to come out any more. Any thoughts?
Old Apr 11, 2015 | 04:42 PM
slacker's Avatar
there is a different cable mounting bracket .. I don't know the exact year , but I believe it's the 96-99 ? it sits more forward then the one you have now .
I have used that bracket you have , but with some cutting and welding
Old Apr 11, 2015 | 05:12 PM
Awww, thanks for jogging my memory as I do now recall seeing something like that. But, after thought, I'll just bend it it should be fine.
Old Apr 11, 2015 | 11:48 PM
wyoming9's Avatar
Red face
Just be careful it does not break.
You do know the nuts should be on either side of the bracket .
I used my 3.0 cable as well.
Old Apr 12, 2015 | 01:53 PM
Thanks, yeah, upon looking at it I should have been able to figure it out. A couple of blows with a rubber mallet and it's good to go now. Why I didn't figure that out in the beginning is beyond me.
First test spin happens tomorrow then off to get the cat back welded on and 02 sensors installed, then a drive and another code check with a good scanner at a repair shop.
Old Apr 14, 2015 | 05:16 AM
vasinvictor's Avatar
I think a lot of us split the trans/throttle bracket down the middle (dremel or sawzall) and bent the throttle bracket down.
Old Apr 15, 2015 | 07:50 PM
RIght on.........yeah, a few blows with a hammer and it bent fine. Good idea about the dremel though.
kazuya2416
Apr 5, 2024 02:17 AM
Alex Bessinger
Aug 31, 2015 09:17 AM
CanRunner
Jul 20, 2015 01:29 PM
rbh261
Jul 13, 2015 12:04 PM
shar
Jul 9, 2015 12:38 PM
