Need help with odd vibration after lift.
I need some help with an odd vibration after my lift. I have a 1997 4runner2wd SR5 V6. I recently installed OME 881s in front with Bilsteins, ARB Tacobumper and 9500lb winch, and OME 890s in the rear with Bilsteins. Has been onfor around 2500 miles and everything has settled in. I have had the alignmentdone. I have had my joints replaced by the best guy here in my town. I have avibration I feel in the drivers side floor board and seat a little (do not feelit on the passenger side) that I notice when I let off of the gas and thedriveline unloads. When I hammer it from stop or as I am at speed I do notnotice anything to mention. I thought it was u-joints and had them replacedwith grease fitting units and also replaced my transmission mount. I cannotfind anything loose under the truck. I did have it loaded up over the weekendwith a couple of friends in the back seat and all of our mountain bike gear anddo not recall noticing it (maybe I am just getting used to it). I have read alot of posts and find nothing exactly like this. Anyone else had this problemand if so what was the cure?
Thanks in advance!!!
Ugh vibrations... don't even get me started. I've learned to live with mine.... Not sure if it's rubber isolators on the body mounts, motor mounts, I am pretending to quit caring anymore.
LOL. This one has 309k on it and runs like a champ. Was going to just ignore it until it got bad enough to find it but figured I would give it a shot. Was thinking maybe pinion angle and drive shaft length since it is 2wd and doesn't have a slip yoke but who knows. Anyone make a 1 inch spacer to lengthen the shaft? Don't really want to spend $400 for adjustable bars and not fix it
Brodetski
Sep 30, 2015 11:50 PM
hiluxinargentina
Sep 30, 2015 05:51 PM
Odin
Sep 26, 2015 06:56 PM
