93-98 T100s All T100 trucks
t100 5 speed conversion
Old Mar 31, 2015 | 02:51 PM
t100morkal's Avatar
Help I'm trying to convert my auto t100 to a five speed truck has a 3.4 motor I have a r150f and transfercase from a early 90s 4 runner with a 3.slow the bell housings are 1 inch difference in length, what do I need to do to make this work? I can't seem to find the Trans that came with that option 96 to 98 3.4 with 5 speed any help would be appreciated
Old Apr 2, 2015 | 11:03 AM
BamZipPow's Avatar
I would just shop on www.car-part.com and see who's got the T-100 5-speed transmission you are looking fer.
Old Apr 2, 2015 | 01:12 PM
blake.nemitz's Avatar
if you do the swap I want to buy the transfer case adapter between your auto trans and tcase. that is if you want to part with it. ive been looking for one for a long time to convert my 2jz a340e to 4wd. t100 is the only one to my knowledge that uses an a340f with a passenger drop case.
Old Apr 2, 2015 | 01:15 PM
the 3.0 r150 with the 3.0 bell will bolt to the 3.4. from your question it seems you have a 3.4 bell? the 3.4 bell is 1 inch deeper with a 1 inch longer input shaft in the trans. as long as you keep the two the same 3.0 bell with 3.0 trans and 3.4 bell with 3.4 trans. the 3vz trans will bolt right up to the 3.4 without needing the 1in. extra depth. just use a 3.0 clutch
Old Apr 2, 2015 | 01:19 PM
the trans you have should bolt right up. the only problem i can forsee is the crossmember being 1in. off. but i bet if you got one with your trans it will work.
Old Apr 2, 2015 | 01:21 PM
http://www.ttora.com/forum/showthread.php?t=159482
here is a decent writeup its not a t100 but its the same engine
jashoeuh
Nov 18, 2024 08:08 AM
BeMiceElf
Oct 10, 2015 09:40 PM
kouki420
Sep 2, 2015 11:42 AM
rustym
Aug 7, 2015 10:39 AM
jgwerth
Jul 16, 2015 03:23 PM
