Sponsored by: CARiD
most lift from shackles alone?
Old Feb 22, 2015 | 07:08 PM
cjskeen14's Avatar
hey i have a pretty stock '81 Toyota pickup on 31s right now but I need to replace the shackles in the front so I thought I might as well do them in the back as well. I'm going to pull the box off and don't mind cutting fenders. I know trail gear sells up to 6". how much lift could I get from just shackles( want to run 33s).
Old Feb 23, 2015 | 04:59 PM
Punchy's Avatar
New shackle minus old shackle length = lift added.
Old Feb 23, 2015 | 06:56 PM
cjskeen14's Avatar
yeah that's what I thought, is it better to go with the kit or should I just buy the plates?
Old Feb 23, 2015 | 08:07 PM
muddpigg's Avatar
Lifting with just shackles can cause driveline vibes in rear as it can effect pinion angle. The vibes will happen more as speed is increased depending on angle.
Front shackle lift will also effect pinion angle but more importantly steering geometry, castor. Depending can cause a death wobble.
Your rig, your choice. Do some research and be cautious of free advice.
Old Feb 24, 2015 | 10:28 PM
etan's Avatar
If I recall there are 2" lift shackles but they are pretty long. I would add a leaf instead.
Old Feb 25, 2015 | 12:09 AM
dropzone's Avatar
Fossilized
Why do you need to replace the shackles?
They are generally pretty durable.
For every 1" increase in shackle length you gain 1/2" lift
Old Feb 25, 2015 | 03:13 PM
cjskeen14's Avatar
that's what I thought but I checked and one on the driver side is snapped and the other is missing.. leaf is literally resting on the frame.
Old Feb 25, 2015 | 04:03 PM
muddpigg's Avatar
To give you an idea of what a little extra shackle length can change. When I rotated the pinion to run dual case with a cv driveshaft. You know short wheel base and dual case. When I first rotated pinion I listened to advice and set the pinion angle 2* below t-case. Well this caused vibes in driveline between 65-70 mph. I added 1/2" longer shackles to rear, it raised the pinion so it points straight at t-case now. So 1/2" is about 2* of course only as accurate as my angle finder.
Old Feb 25, 2015 | 04:21 PM
cjskeen14's Avatar
so I should probably go with stock lentgh shackles. I think they are 5".
suppra87
Jul 15, 2021 05:15 PM
1uzRunner
63
Nov 10, 2018 03:58 PM
punks_is_4x4
May 31, 2016 06:03 AM
matthew138
Sep 3, 2015 08:21 AM
Ryall
Sep 2, 2015 06:48 AM
