94 4runner
94 4runner
picked up a 94 4runner its going to be kind of a slow build at first
it is an auto but I still have my old 90 4runner 5spd so ill be 5spd swapping it as well
so far I have 5" tg hd front leafs built Toyota axles with 5.29's spool rear open front an 36" iroks an v6 to gear driven tcase
been doin general maintenance stuff
trans filter/fluid auto shifts better
changed oil stuff was really dark
did tune up found out the PO put a k&n air filter
put my manual hubs instead of the flanges figured couldn't hurt till I do the sas
I seam to have a surge when driving an every so often I get a stumble when taking off from a stop
ill get pic's when im able to
right now its a stock 94 4runner on near new ranger a/t thunderer 30/9.5r15 has 4.88 code think its a forest green with just about every option though the factory cd/tape worked one time after I got it
don't think its ever been offroad till I almost got it stuck in my back yard I can see the markings on the frame from the factory it's even had the factory spare tire that has never been dropped think the date code on the tire was mar 4th 1993
im going to try chevy 3/4 or 1ton rear 63's 2" blocks an 7" shackles see were it sits if it takes any more then that to match my 5" front springs ill just buy rear springs
lol it was all going good with the front end till I found out the Tacoma I got the calipers/rotors off of at some point was swapped to the bigger brakes so I ended up with the 16+ brakes were as the Tacoma should have had the brakes for 15's
had to change calipers/rotors they didn't fit 15inch wheels an I didn't notice last yr when I got the calipers/rotors some one at some point swapped bigger brakes on the truck I got them off of
so today went to the pnp found a 99 taco with the correct calipers/rotors for 15inch wheels then went to the auto parts store got brake hoses for 99 Tacoma an 2 rear brake hoses for 4runner to extend the hoses
the 4runner rear hoses are 14 5/8 inches
an the front hoses for the 99 Tacoma 22 1/2 inches
yay wheels fit with the 99 taco brakes had to grind alittle bit around the wheel mating surface but they clear a lot better then the others I had on there
ill keep the other calipers/rotors for when I need new tires ill switch to 17's an either 36's or 37's tires
