94 4runner
Old Feb 14, 2015 | 05:13 PM
bad luck's Avatar
94 4runner
picked up a 94 4runner its going to be kind of a slow build at first
it is an auto but I still have my old 90 4runner 5spd so ill be 5spd swapping it as well
so far I have 5" tg hd front leafs built Toyota axles with 5.29's spool rear open front an 36" iroks an v6 to gear driven tcase
Old Feb 15, 2015 | 02:04 PM
bump530's Avatar
Sounds like a good project. Pics?
Old Feb 15, 2015 | 02:45 PM
bad luck's Avatar
ill get some pic's asap
I cant wait to really dig into this 4runner if I don't get this DD im looking at im just going to put the money I was going to spend on that into the 4runner
Old Mar 2, 2015 | 05:46 PM
bad luck's Avatar
been doin general maintenance stuff
trans filter/fluid auto shifts better
changed oil stuff was really dark
did tune up found out the PO put a k&n air filter
put my manual hubs instead of the flanges figured couldn't hurt till I do the sas
I seam to have a surge when driving an every so often I get a stumble when taking off from a stop
Old Mar 2, 2015 | 11:31 PM
Terrys87's Avatar
Welcome to Yotatech and looking forward to seeing your project. A little at a time and it will happen and get completed. Every little bit is a step is a step closer.
Old Mar 3, 2015 | 05:39 AM
rattlewagon's Avatar
Sounds like a cool project! Where are the pics!
Old Mar 3, 2015 | 09:11 AM
bad luck's Avatar
ill get pic's up as soon as I can
have to replace my cell dropped it the day I picked up the 4runner when I was loading it onto the trailer
Old Mar 5, 2015 | 07:13 AM
muddpigg's Avatar
Welcome, sounds fun.
Old Mar 5, 2015 | 06:03 PM
Gevo's Avatar
Yah, when you have a build thread people demand pics!
Old Mar 5, 2015 | 08:58 PM
Redwood 4runner's Avatar
Thumbs up
Old Mar 6, 2015 | 06:02 PM
bad luck's Avatar
ill get pic's when im able to
right now its a stock 94 4runner on near new ranger a/t thunderer 30/9.5r15 has 4.88 code think its a forest green with just about every option though the factory cd/tape worked one time after I got it
don't think its ever been offroad till I almost got it stuck in my back yard I can see the markings on the frame from the factory it's even had the factory spare tire that has never been dropped think the date code on the tire was mar 4th 1993
Old Jun 6, 2015 | 01:23 PM
bad luck's Avatar
see if this works
Attached Thumbnails 94 4runner-cam00008.jpg   94 4runner-cam00009.jpg   94 4runner-cam00014.jpg
Old Jun 6, 2015 | 01:26 PM
bad luck's Avatar
yay figured it out
Attached Thumbnails 94 4runner-cam00015.jpg   94 4runner-cam00016.jpg   94 4runner-cam00017.jpg
Old Jun 6, 2015 | 01:27 PM
bad luck's Avatar
Old Jun 6, 2015 | 01:39 PM
bad luck's Avatar
im going to try chevy 3/4 or 1ton rear 63's 2" blocks an 7" shackles see were it sits if it takes any more then that to match my 5" front springs ill just buy rear springs
lol it was all going good with the front end till I found out the Tacoma I got the calipers/rotors off of at some point was swapped to the bigger brakes so I ended up with the 16+ brakes were as the Tacoma should have had the brakes for 15's
Old Jun 7, 2015 | 02:35 PM
bad luck's Avatar
after I get the susp swap done my next tax money is going to a 3.4 / 5spd swap cant wait
ive been waiting for 4yrs to get going on another 4runner I cant wait to get it done
Old Jun 7, 2015 | 04:38 PM
bad luck's Avatar
think I need to move my steering box
an got board took some pic's cant do anything more till I get my paycheck
Attached Thumbnails 94 4runner-cam00020.jpg   94 4runner-cam00021.jpg   94 4runner-cam00022.jpg
Old Jun 8, 2015 | 06:10 PM
bad luck's Avatar
had to change calipers/rotors they didn't fit 15inch wheels an I didn't notice last yr when I got the calipers/rotors some one at some point swapped bigger brakes on the truck I got them off of
so today went to the pnp found a 99 taco with the correct calipers/rotors for 15inch wheels then went to the auto parts store got brake hoses for 99 Tacoma an 2 rear brake hoses for 4runner to extend the hoses
the 4runner rear hoses are 14 5/8 inches
an the front hoses for the 99 Tacoma 22 1/2 inches
Old Jun 9, 2015 | 04:09 PM
bad luck's Avatar
yay wheels fit with the 99 taco brakes had to grind alittle bit around the wheel mating surface but they clear a lot better then the others I had on there
ill keep the other calipers/rotors for when I need new tires ill switch to 17's an either 36's or 37's tires
Old Jun 9, 2015 | 07:57 PM
bad luck's Avatar
well that was to much fun driving around my back yard with lifted front stock rear kinda reminds me of a English bulldog
