3.4 or 1UZ clearance needed for crossover in 85 truck
So I currently have a flat belly 1985 toyota truck 22RE with duals. I have been toying around with the idea of throwing either a 3.4 or a 1UZ to spice things up. The front is 3 linked so one of my main issues would be having to run a crossover exhaust set up. However, the way I have made my tranny mounts and tunnel for the 22RE flat belly I just don't know how much clearance there is in between the back of the motor and the cab to run a cross over pipe.
I could always cut the cab, but just wanted to see what all pictures are out there showing the end of the bell housing in relation to the cab etc.
I would do that if my slave cylinder was not on the pass side as well as my link. There is just no room for how my current 3 link is set up. Not saying I couldn't change it but With the drive shaft also being on that side it makes it near impossible.
slacker
13
Sep 6, 2015 06:14 AM
