General Electrical & Lighting Related Topics Ask here for electrical, wiring, and lighting info for your rig that could apply to all years
No passenger hi or low beams.
Old Nov 17, 2014 | 04:57 PM
bobbyd1989's Avatar
I have an 88 xtra cab and the passenger side headlight kind of doesn't work. Hi beam does not work and when the low beam is on, the light turns on but it barely lights up. The driver side hi/low beams work fine. Fuses are fine. I plugged in another light and it does the same thing. Very dim low beam and no hi beam. Any ides? THANKS!
Old Nov 18, 2014 | 12:04 AM
wyoming9's Avatar
Red face
I would look for a corroded plug or damaged wires close to that light .
Old Nov 18, 2014 | 12:17 AM
BigBluePile's Avatar
The contacts in the steering column are dirty.
Old Nov 18, 2014 | 04:41 AM
bobbyd1989's Avatar
I will check both of those potential problems today and let y'all know tonight, thanks!
Old Nov 18, 2014 | 06:49 AM
Terrys87's Avatar
Some things to check for.
https://www.yotatech.com/forums/f199...l#post51724567
Old Nov 19, 2014 | 04:20 PM
bobbyd1989's Avatar
Thanks for all the advice! Turned out to be a bad contact where the fuse is. Pulled it out, cleaned out alittle corrosion where the fuse goes in and now it works perfect.
Old Nov 20, 2014 | 03:06 AM
Terrys87's Avatar
Glad to see you got it fixed. It is nice to know what the problem is and glad you mentioned what it was.
Old Nov 20, 2014 | 08:38 PM
bobbyd1989's Avatar
Yes! This yotatech community is an awesome place for knowledge and opinions on just about any problems or questions you might have. If I've ever run into a problem or need advice on something I always get it here. Glad I joined, thanks a lot guys!
Old Dec 3, 2014 | 04:50 PM
YotaInSC's Avatar
Do you guys thinks the same solution would work for this:
No low beams on passenger nor drivers, only passenger high beam works, corners work fine, no high beam indicator. 88 toyota pickup.
Old Dec 3, 2014 | 06:13 PM
bobbyd1989's Avatar
Did it all happen at once? Might be a bad fuse for the driver side and the bulb on the passenger side might have just lost its low beam.
Old Dec 4, 2014 | 04:00 AM
Terrys87's Avatar
RAD4Runner build thread has a link somewhere on a headlight harness that can be bought off of ebay for a fair price. The way Toyota did the electric on these is a poor way of doing it. I am eventually going to replace mine with one when I get to it.
In my opinion, these trucks were designed for the standard headlights and most of us put in Halogen headlights and I think that just puts a strain on the whole harness and especially the combo switch.
As far as electrical troubleshooting, I am weak in that area, but would suggest cleaning all contacts checking your grounds.
Old Dec 4, 2014 | 04:55 AM
4Crawler also sells a replacement harness.....
Old Dec 4, 2014 | 05:18 AM
Terrys87's Avatar
Thanks BigBluePile. I did not know that and would rather give my business to Roger.
Old Dec 4, 2014 | 05:28 AM
Troof.
http://www.4crawler.com/4x4/CheapTri...adlights.shtml
Old Jan 3, 2015 | 02:03 PM
Odin's Avatar
The yellow wrapped kit that link shows is the Putco kit.
I purchased that kit before I had a Toyota to run 100/90 bulbs. This is a totally Taiwan produced harness and the wire size doesn't conform to the American AWG (American Wire Gauge) standard. Because I was unsure of the wire size used I cut one main power and ground end off to look at the actual thickness of the wire. I chose not to install it because it looked like the wire size falls at about 16 AWG and not any bigger. While that's ok for 55/60 watt bulbs and some HID's it's not so good with higher wattage bulbs. I don't think my 100/90 bulbs would have been real be real happy with that.
mussy01
Dec 13, 2016 08:20 PM
raptor510
Aug 19, 2015 02:15 PM
shisha1999
Aug 14, 2015 01:33 AM
RobotMoose
Diesel Swaps
Aug 2, 2015 11:00 PM
itzmywife's
Jul 25, 2015 04:55 PM
