22re runs 30 seconds, then dies
Hey all, I've got an 88 4runner with 22re, manual tranny. I've searched and searched and not found anybody with my particular issue.
I removed the p/s pump yesterday and after re-installing the intake tube, the truck starts up fine, idles great until about 30 seconds then it starts missing and progressively gets worse until it finally dies. I have checked all the vacuum lines, pulled the plugs, checked the wires, checked the grounds. I had a fairly significant hole in the elbow of the intake tube right before the TPS but I patched it up today, albeit just with duct tape. I only removed the parts included in the p/s system and I just don't understand why the engine is behaving differently.
There is a ground that is on a lot of 22Rs positioned on one of the power steering vane pump bracket mounting bolts. Verify this ground is good and attached to the engine block.
I'm assuming the trucka engine ran fine prior to tamping with the power steering system..?
I looked around that area for the ground, but didn't find any loose wires hanging. Everything seems to be connected. And yeah, the engine ran perfectly before this. I started it up this morning and she ran perfect for a few minutes then as she started warming up it sputtered and died.
Air Flow Meter air door sticking..? Air Flow Meter wiring harness damaged/disconnected..? Air intake leaking from p/s fast idle vacuum valve disconnected..?
Air intake hose between Air box and throttle plate damaged...?
same problem
hows every1 doing? excuse me for jumping in afraid im part of the prob not solution! quik bakround bout myself ..... ive changed some parts in my day but when it comes to motors IM ONE HUGE IGNOURNT F&@K!!! got tired of being takin advanteged of so decided to rebuild my 88 22re myself. did i mention i get frustated & grouchy just thinking about mechanic work , for the simple fact that i dont understand nuttn bout motors.any way my point is ive got the same prob, after 3 weeks of cleaning, sortn , 2wks of taking parts to machine shop & another (LITERALLY) 2wks of put'n it back together 2day i got it to stay on for more than 8sec. i have the book but it confuses me tried to get all the hoses rite but i know i screwn up somewhere . can SOME1 PLEASE HELP & SEND ME AN ACTUAL FOTO OF THEIR MOTOR WITH DETAILS OF ALL THE HOSES AN STUFF? MINE HAS 3 VSV .. THANKS IN ADVANCED from ONE FRUSTERATED IGNOURNT F&@K!!!
Jnkml
Jul 6, 2015 01:20 PM
