1999 Tacoma 3.4L no power.
Hello everyone, my name is Andy and my Tacoma has little power and will not go any faster than 65. If I push the gas to accelerate it coughs and drops down at least 10mph and will not speed up again unless I let off the gas to about half way. I have changes plugs and wires air filter and fuel filter but I'm not very mechanically inclined. Any ideas and suggestions would be great Thanks a lot.
No clutch or transmission slippage and no driving around on 1/4 tanks. 250,000 miles check engine light is on. Thanks
may not be getting enough fuel. when you plug the pedal down, you open the air intake, the computer senses that and adds go-juice. could be any number of bad sensors, throttle position, airflow, o2 etc.
Have you tried flooring it? At WOT I know the engine goes into "closed loop" mode and bypasses the o2 sensor and it would magically work again. if it were that.
Anyway, go to your local advance auto or other auto parts stores and ask to borrow a code reader. plug that sucker in your OBD2 port and it will likely tell you that one or more sensors are bad. It miiiight say that like all of your sensors are reading wrong, or that you have a misfire. In my experience, when one sensor is working wrong, a bunch will read wrong because the motor isn't running right.
IF THE CEL IS FLASHING don't drive it. That's a mechanical problem.
Read the codes, replace sensors, evaluate.
You said you replaced plugs. Were any of the plugs fouled with black soot? Especially like if one side was sooty and the other was clean that means o2 sensor.
No offense but your truck is TELLING you the problem by triggering the MIL light and you join a forum to diagnose over the internet without even trying to pull the code and see what it's telling you?
C'mon man!
C'mon man!
Lol exactly! So many people have a problem and their check engine light is on but haven't checked why. Do people just not know what the light is for? Or think it's a trick or something?
I thought when that light was on the engine was feeling neglected and needed some tender loving care .Like a nice candle light dinner and nice warm bath seems to work in most cases .
In severe cases I have found Chocolate does wonders
A flashing CEL does NOT mean mechanical damage. It means there is an unsafe condition for the catalytic converter. Usually too much fuel from a misfiring cylinder. Possibly too lean from low fuel pressure. Not a solution to your problem, but clearing up some information.
1uzRunner
63
Nov 10, 2018 03:58 PM
Bourbonblues
Dec 15, 2017 05:43 PM
FS[FourCorners]: First Gen Tacoma/4Runner Manual Hub Spindles
G-off
Dec 29, 2015 12:44 PM
DiggnDeep
Sep 3, 2015 02:45 PM
Is your Clutch or Transmission slipping ??
