Top two bell housing bolts
Old Aug 27, 2014 | 02:42 PM
ditypup's Avatar
Hi, I could swear that the last time I pulled the engine on my 93 4x that I was able to crawl under the truck and actually see the top two bell housing bolts. But I been under there today and I can't see them at all. Now wondering how did I get them out. I'm not pulling the trans with the engine.
Anyone have any methods to do it?
Thanks
Old Aug 27, 2014 | 02:45 PM
Sturmcrow's Avatar
You may need to lower the crossmember a bit to see them. On my truck, I can see the bolts from the wheelwell too, which helps if you have a helper to guide the socket for you.
Old Aug 27, 2014 | 03:19 PM
ditypup's Avatar
I can get the drivers side out from above . Lets hope I can see the passenger side from down below. I might have to lower the trans a bit. thanks.
Old Aug 27, 2014 | 04:18 PM
Grego92's Avatar
I used this type of wrench
Driver's side
Passenger side
Old Aug 27, 2014 | 06:37 PM
slimbobaggins's Avatar
+1 to lowering the trans. Support with a trans jack or floor jack/ plywood, drop it an inch or two, so much easier.
Old Aug 27, 2014 | 06:52 PM
ditypup's Avatar
thanks guys.
Old Aug 27, 2014 | 06:57 PM
snobdds's Avatar
Greg...why didn't I think of that.
I used, however, a flex head ratcheting wrench. Seemed to work.
Old Aug 27, 2014 | 07:43 PM
scope103's Avatar
Originally Posted by Grego92
[/URL]
Ah, gee, Grego92. Couldn't you have cleaned up your engine compartment a bit before taking pictures?
Old Aug 27, 2014 | 09:38 PM
nothingbetter's Avatar
another option for future searchers, lift the engine a bit, pull out the engine mounts and drop the engine the extra inch or 2, gives much more access to those bolts.
Old Aug 27, 2014 | 10:10 PM
dropzone's Avatar
Fossilized
24"+ of extensions work too
Old Aug 28, 2014 | 05:49 AM
Gevo's Avatar
LOL. Show off!
Old Aug 28, 2014 | 07:11 AM
Grego92's Avatar
That was a Husky 3/8" extendable flex-head ratcheting socket wrench.
Snobbs idea of a flex-head wrench is good too, maybe a large diameter pipe to go over it if you need some leverage or just longer so you don't have to reach down as far while ratcheting.
Nothingbetter's idea of removing the mounts to get some more space is a good idea to keep in mind.
LOL, been there before, gotta use what you got!
Old Aug 28, 2014 | 01:42 PM
osv's Avatar
osv
that's what i do, with a 1/2" universal joint plugged into the socket.
jasonty
41
Dec 23, 2018 01:00 PM
calderp
Engine Swaps
Aug 16, 2016 05:15 PM
calderp
Jul 27, 2015 09:58 AM
CanRunner
Jul 20, 2015 01:29 PM
Iceman4193
Jul 15, 2015 04:48 PM
