Advice on removing IAC valve without stripping screws
I never saw that engine but on my 3.4 I just take off the throttle body put it in a vice and take them off. Using a good screw driver not a cheap one
That sounds more like the ECM is not seeing the AC is turned on rather then a bad IAC
Are you getting the P0505 code.
Not a GOOD screwdriver but a JIS screwdriver. Regular Phillips will strip. Get a set of JIS drivers for anything Japanese, from Yamaha Waverunners to Canon cameras.
http://www.instructables.com/id/When...rial-Standard/
Pull them off and match the internal diameter up at the local auto parts store. Most places have vacuum hose in bulk and will cut off whatever you need.
Sep 4, 2015 09:27 AM
Iceman4193
Jul 15, 2015 04:48 PM
