Need help pulling head gasket 94 4x4 Truck 22R
Need to know how to remove EFI intake to get to the head gasket on my 94 Toyota 4x4 Pickup. It's the 22R motor. I've gotten all the way down to the EFI intake and cannot get past it. Secret bolts? Any clues? Links, threads, videos? Any help appreciated!
Breaker bar for what. Crank case bolt? If te efi is sticky and you know you have a the bolts out you should be able to lightly tap it loose. Just saying this so you don't damage anything. Not that you would but I might
. But for the crankcase bolt put the breaker bar on the nut run it up snug under the passenger frame rail then bump the starter. Should come loose. Re torquing it is the more challenging part. Good luck hope this helps.
voiddweller
19
May 2, 2016 09:10 PM
