Will an 88 4Runner fuel tank fit an 89 PickUP?
My fuel tank is leaking. I have a chance to buy a complete fuel tank from a 1988 4runner. I have done some research and it seems it will fit. That my old dependable truck and a picture of the fuel tank. I'm a Sculptor not a mechanic so I need some help from you experts. I have added a picture of my fuel tank. Looks nearly the same to me. Thanks
On that truck you might could make it fit. The fill neck and vent tubes are oppisite of each other on the runner and trucks, but since the body/ bed isnt in the way it might. Otherwise no they are not interchangeable.
Fuel Tank.
No other opinion?
Meausre the width and length for a better idea as well. What is wrong with your original tank? If it is rusty on the inside, I have cleaned several tanks. The tank you are getting maybe be rusty on the inside as well. All builds I have done below or elsewhere, the tanks are in bad shape and is one reason I posted alot of information in each of my builds to show what they are like in my climate. It is something that is over looked and is out of sight and out of mind. Check your return line a well since you are in to the fuel system.
Fuel Tank
Meausre the width and length for a better idea as well. What is wrong with your original tank? If it is rusty on the inside, I have cleaned several tanks. The tank you are getting maybe be rusty on the inside as well. All builds I have done below or elsewhere, the tanks are in bad shape and is one reason I posted a lot of information in each of my builds to show what they are like in my climate. It is something that is over looked and is out of sight and out of mind. Check your return line a well since you are in to the fuel system.
If the runner tank does not work for you, you can take that tank and clean it up on the inside and then use Red Kote to seal the inside of the tank. It will seal up some good sized holes.
Leaky fuel tank
All I can say is Wow on the Red Kote. I asked all around for such a product and no one knew about this. I don't think I will need it with the new tank. But I will spread the word. I had to turn the new tank upside down to wire brush, sand it, and paint it. Is that a problem for the fuel pump? Damn I wish I had know about Red Kote before. Thanks for your experience. I just hope the new take has not other problems. My mechanic is on vacation till the 14th. I will let you know how I make out. Thanks again. BTW I'm in Rhode Island and theres a guy here in West Greenwich that says he has the largest Toyota Junk Yard in the state. If anyone needs to know more email me.
Here is what I use. On any of my threads below, on the first few pages, I have info on cleaning them out and such. These tanks get in bad shape. Also check your Return line. It wont hurt the fuel pump being upside down. I would pull the Fuel Float if it was me. You will get a good view of the tank and see what it looks like. I have seen a quarter inch rust built up in them and it easy to clean with white vinegar. Takes a few days.
89 Toyota Long bed with dual wheels, Guess what?
My mechanic called me yeterday to tell me the new tank I was assured would fit my truck is to tall and they cannot make it fit. Nice! I live in RI. Charles if you know him has already tried to find me a tank which he did but its the wrong one. I'm loosing money everday with out my truck. Does anyone know where I might find a tank to fit it? the VIN# is JT5VN94T7K0001693. Oy Vey! Thanks for you help!
Call and make sure this is for your truck. They should have one available.
http://www.ebay.com/itm/New-Fuel-Tank-Gas-Silver-Truck-17-Gallons-Toyota-Pickup-95-94-93-92-91-90-89-88-/370886440872?pt=Motors_Car_Truck_Parts_Accessories&fits=Year%3A1989%7CMake%3AToyota%7CModel%3APickup&hash=item565a8df7a8&vxp=mtr
Fuel Tank. Oy Vey!
Anyone have a rope I can borrow? lol. Once again my mechanic has called me to say my fuel tank bracket is shot and the gas gauge sending unit. omg! Does anyone know where I can pick up either of these for a reasonable price? Toyota is outrageous! Also the units from the other tank are too long. My fuel tank bracket is only about 10" in length. As usual any help is greatly appreciated! Thanks
I may have some information for you guys. I have found the parts I need at a very good price at this place. OEM Toyota Parts Group. 1-877-493-4580. Ask for Greg. He had the fuel pump bracket I needed for $138.99. They Toyota Dealer near me and the guy is a friend of mine could not get it for less than $200.00. Greg was very helpful. Thanks for your help as well.
On a pickup especially, I spend a lot of extra time keeping on top of the tank clean. The way it sits under there is a good trap for dirt on it and on the frame as well. Yours being a flat bed is a little different but on the trucks with a regular bed, it needs extra attention. Glad to see you are about to get this problem fixed. I am sure it has been frustrating.
Fuel pump bracket, new problem. Oy Vie!
I found a fuel pump bracket, gas gauge sending unit, gaskets for both and the short rubber hose for the fuel pump all for $232.00. Finally!
The Circuit Opening Relay is right behind the passenger speaker cover. Will it run with the jumper in below? This will energize the pump. You do not want to keep it installed, just to see if the pump circuit is working. If so, then you can start looking at other issues. If not then you may have a bad pump or wiring.
Did he get the correct bracket? If it is the wrong one it may not be picking fuel up from the bottom. I would fill the tank and see if that makes a difference. These brackets do vary in length by alot. If he got one to short, it may just not be picking up fuel.
Fp +B Fuel Pump Test for 87 and newer. Use a paper clip for better results.
