92 Toyota 3.0 pickup stalls after start
I am having trouble with getting my vehicle on the road. i recently spark plug wires,distributor cap, and replaced the mass air flow sensor, which i thought was the cause of my problem.
It ran good while it did and started to run rougher each time i tried starting. which was about three times. i noticed the smell of gas as if the engine was flooded after the initial start up and stall. Any suggestions would help.
take the air inlet manifold off and check the fuel rail for leaks , while your in there check your injectors , a injector rebuild kit is ˟˟˟˟ all and easy as fcuk to do .
there is also a tiny fuel filter in your cold start injector that alot of people dont know about , take the cold start injector out and have a look where the fuel gos in you will see the filter , most of the time they are blocked with crap or deteriorated .
if it is deteriorated then there is a good chance the filters in your injectors are blocked with crap .
good luck
good luck
