General Electrical & Lighting Related Topics Ask here for electrical, wiring, and lighting info for your rig that could apply to all years
1986 4runner cigarette lighter suddenly stopped
Old May 2, 2014 | 09:16 AM
tinigunner11's Avatar
Hi guys, I have a 1986 4runner that just developed a problem. My cigarette lights suddenly stopped working. The PO installed 2 aftermarket outlets and wired those and the factory plugs to be constant hot. And they've worked great up until last Wednesday, now being friday I still cant figure it out. I had used them that morning and they quit by early afternoon with no warning. I've changed all the fuses I can think of, and the radio and the clock still work. its got me stumped any help?
Edit: and I've searched every toyota and non toyota forum and google. beyond belief.
Old May 2, 2014 | 01:32 PM
wyoming9's Avatar
Red face
Just what have you checked??
How do you know your devices did not die and not the sockets?
Check with your meter for battery voltage .
Some of the cheap Chinese plugs are so small as to cause problems.
Old May 2, 2014 | 04:06 PM
RAD4Runner's Avatar
Yup. You have a volt-meter? STOCK Cigarette lighter circuit is here:
However, you said PO made the added outlet and stock lighter socket constant hot. Therefore, he must have tapped that line somewhere and NOT to the stock lighter fuse.
IF he did it right, he should have provided an after-market fuse for it. You need to find that line and fuse, trace it back to battery, and see where you lost power.
Old May 4, 2014 | 03:37 AM
wyoming9's Avatar
Red face
So just what was befuddled that it was not working??
Old May 4, 2014 | 04:58 AM
HighLux's Avatar
Its a sign to quit smoking. Your Toyota cares about you.
Old May 4, 2014 | 11:07 AM
Nervo19's Avatar
^^^I was thinking the same OP probably wants to charge his cell phone though.
Check for those blue clamshell electric clips. If he used those and he installed something electrical without a fuse proceed to the store and get a fire extinguisher to carry in your vehicle.
Old May 26, 2014 | 09:38 AM
Thank you for all the responses! Sorry I didn't update sooner, Been crazy busy and just started a new job. But the problem was a blown aftermarket fuse that the PO stuffed way under the dash. So easy yet complicated fix. Thanks again guys!
Jun 1, 2021 01:51 PM
mskalmus
May 28, 2017 07:51 AM
icentropy
Jul 11, 2015 07:21 AM
raiderhawks00
Jul 8, 2015 06:23 PM
Jnkml
Jul 6, 2015 01:20 PM
