Sponsored by: CARiD
89 4x4 rebuilt missing vacuum lines HELP
Old Apr 1, 2014 | 02:53 PM
ca1351's Avatar
I bought a 89 4x4 ext cab yota. Rebuilt engine is running good EXCEPT missing over half the vacuum lines and the guy that did the rebuild didn't mark anything. I've done all I can do and need some exp help. Thanks
Old Apr 1, 2014 | 02:54 PM
ca1351's Avatar
its a 89 22re
Old Apr 2, 2014 | 01:43 PM
thefishguy77's Avatar
Take pictures of it for us and post them. I could post probably 100 pics o different vacuums lines. But they may or may not be any good to you. Hell if you don't need your egr to function properly for emissions then cap them and drive it if she ain't throwing codes.
Old Apr 3, 2014 | 06:32 AM
ca1351's Avatar
I will get a pic and post it shortly, i bypassed the egr and put in a resistor to clear the code out. after it warms up It is still idle surging from 500 to 2500 rpm until I tap the gas then it will drop to 750 and idle fine. In the morning it fires right up, jumps up to 1800 for a couple of min and drops down to 750rpm. T Thanks for your help with this.
Old Apr 3, 2014 | 06:52 AM
ca1351's Avatar
Old Apr 3, 2014 | 12:26 PM
Well looking at your picture I see a lot o open vacuums lines. Are they uncapped to show what your looking for or have they always been uncapped? If always then cap them and see how she runs. If not well I will look for helpful pictures. I will try to post some later today
Old Apr 3, 2014 | 05:34 PM
Hope these help. Most are egr related. so if you have disabled the egr then you should be able to cap the egr one and forget about them.
That should get you started. Let me know if you need more or different angles. I will see what I can come up with.
Old Apr 4, 2014 | 05:06 PM
ca1351's Avatar
That is a big help, thank you. I will get as far as I can with this and let you know. Thanks
Old Apr 4, 2014 | 07:46 PM
Anytime
smthwsn357
May 1, 2024 07:28 AM
icentropy
Sep 16, 2020 02:47 PM
Sep 4, 2015 09:27 AM
87turboPA
Jul 12, 2015 07:49 AM
87turboPA
Jul 9, 2015 05:58 AM
