2001 4runner p0300 p0303 vsc off vsc trac
Learned a lesson in trouble shooting today.
If a 2001, or about, 4runner has random cylinder misfire (P0300) and number 3 cylinder misfire (P0303) codes, plus VSC OFF, VSC TRAC and ENGINE lights are on the problem, my friend, is not a mechanical one.
Vehicle sounded real good when scanner reported the codes. No misfire could be detected.
Just in case I swapped #3 coil with #2 coil and nothing changed.
Reset codes and all was well..until
Checked the battery and it was 3 months over it's expiration date with a heap of corrosion hidden under the red battery boot. A little battery terminal cleaner and silicon di-electric grease and all was well.
Possible low voltage caused the erroneous errors.
In a couple of days the 4runner will get a new battery and the fix, hopefully, will be done.
Flying91
45
Apr 11, 2024 04:39 PM
FS[PacNorWest]: 1987 Toyota 4Runner $1800 Whidbey Island, WA
coreyedwards7611
Jan 16, 2016 06:38 PM
BeMiceElf
Oct 10, 2015 09:40 PM
mengquis
Jul 13, 2015 10:39 AM
