U shaped bypass coolant hose on back of 3VZE
Old Mar 19, 2014 | 06:58 AM
scrid's Avatar
"U" shaped bypass coolant hose on back of 3VZE Rear leak
Hello everyone, yesterday I blew that U shaped hose on the back of my 3VZE.
I did some searching in the forum to find the correct name for the hose so I could look it up on the local auto parts stores website.
Found a forum post by someone who gave a part number but when I ordered it not only was it too short in length but also the I.D. was too big.
I went in the back room at the parts store and found a better match.
It's a Gates 18206. It's somewhat longer but can be cut to fit perfectly and works well with the original clamps too.
Heres a pre-cutting picture next to my original one.
Also, I was able to change mine without removing the plenum as I see alot of talk here about. It wasn't too bad using a pair of the "Stork" needle nose pliers. I'd rather do the hose replacement on the 3VZE then a starter removal!
Took all of about 10 minutes one the engine cooled down.
Just thought I'd post to maybe help someone else out.
Old Mar 19, 2014 | 08:45 AM
scope103's Avatar
Just out of curiosity, what did you think the part number was?
It looks like it's 16267-65011. HOSE, WATER BY-PASS, NO.3. http://www.toyotapartsoverstock.com/...626765011.html
Old Mar 20, 2014 | 04:24 AM
scrid's Avatar
The hose someone else had listed here was a Dayco A71359 which is too big of an I.D. and almost too short as well.
bigjstang
Jun 2, 2025 03:56 PM
Avenged
Jul 9, 2015 07:55 AM
coryc85
Jul 7, 2015 04:05 AM
elwood73
Jul 5, 2015 07:07 AM
