92 22RE Hard to Start After Rebuild
Old Mar 17, 2014 | 04:32 PM
nc4x4's Avatar
Ok I rebuilt top end and put it back together. Got it fired up. It ran on a Sunday and Monday it wouldnt hit a lick at all. So I pulled a plug and no fire. AM2 fuse was blown so I started testing coil, pick up in dist, went ahead and replaced cap/rotor button...still nothing. You could put a new AM2 fuse in it, have someone just turn the key to ACC and the fuse would smoke up and pop it. So I got a igniter off another truck and replaced fuse. It didnt blow on the ignition being turned and it started firing. It cranked after a few tries.
Now after all that it was still kinda hard to start. It will try to bust off but wont crank. You can smell the fuel so I think its getting plenty of fuel in the rail. You can let it sit and repeat process 3 or 4 times and it will finally crank. I tried checking to see if I had the injector wires wrong but they are all the same( black with red stripe & white with red stripe ). I read a forum on pirate4x4 I think that said something about yellow & white/red on 1&3 and yellow & blue on 2&4. Clearly I dont have those colors. Must have been pre 1992. Could I have injector wires backwards? What else could it be other than that or cold start injector?
Old Mar 17, 2014 | 06:05 PM
92yoterDD's Avatar
Does it turn over very slowly? If it doea then you have the ignition timing off. Pull distributor and restab it correctly. I dont think you can get the injector wiring wrong. On mine the wires are only long enough to reach the correct injector. The
JF9243176
Oct 8, 2017 04:21 AM
Ichneumon
Sep 27, 2015 04:21 PM
renorunnerguy
3.4 Swaps
Jun 28, 2015 09:18 AM
JF9243176
Jun 24, 2015 04:53 AM
jmc88runner
Jun 18, 2015 03:39 PM
