98 Tacoma Engine Swap, Suggestions?
Old Jan 30, 2014 | 10:10 AM
98yotaman's Avatar
Question 98 Tacoma Engine Swap, Suggestions?
I am replacing the engine in my V6 98 Tacoma after the old one died, does anybody have suggestions on a new clutch, water pump, or even upgraeds I could do?
Old Jan 30, 2014 | 12:39 PM
98SR54RUNNER's Avatar
I know nothing about clutches and MTs, but as far as the water pump and other engine accessory stuff, go OEM all the way. If you're going to go through all the trouble to pull the old engine out, you may as well go ahead and splurge for OEM timing belt, water pump, pulleys, tensioner, etc. It's obviously incredibly easy to do this stuff while the engine is out. If you're going to spend the bucks to breathe life back into your rig, you should do it right.
Old Jan 30, 2014 | 02:43 PM
98yotaman's Avatar
Thanks, I will look into it.
Goddamnboh
3.4 Swaps
12
May 11, 2016 09:22 PM
vasinvictor
Jan 20, 2016 12:39 PM
noahstancik
Jul 10, 2015 11:18 AM
greenbuggy
Jun 28, 2015 10:40 AM
Alex Bessinger
Jun 28, 2015 10:05 AM
