32/36 weber electric choke
so I have a 32/36 weber on my 22r I cant get the choke to work ... I got 12volts there only when ignition is on or truck running the problem.. no matter where I set the choke plate tension wise it don't wanna open slowly. I had it work once set the high idle it slowly opened but not matter what it wouldn't close even after the next day snapping the throttle didn't help anyone ever had a problem with this. this is a brand new carb. whats the proper procedure in doing this any help would be great thanks.
Sounds like you have a larger amperage than what is needed for the carb IMO. I have mine wired into the stock wiring. Its a round green connector and if I am not mistaken it is the lower left connection. There are 4 possibilities though.
Beamed from my dumb phone using Yotatech
