hairline crack rear diff housing
have a 97 4runner sr5 2wd and just replaced the seal to the 3rd as it was leaking. well, it was still leaking....did closer inspection and the housing itself has a hairline crack....options?
1. i imagine a replacement housing would be expensive not to mention the labor on top?
2. can it be welded? probably a short term fix
its my daily driver with 280k and i dont go offroad....any advice would be appreciated.
thanks!
thanks!
Rear axles are pretty easy to swap.
Unbolt the e-brake, brake lines and abs sensor.
Then cut the u-bolts. Don't waste your time with unbolting them.
Insert new axle and install new U-bolts.
jerusry
Oct 19, 2015 05:28 PM
Poncho0206
Jul 10, 2015 06:21 PM
