headlight & turn light wiring adapters
Old Jan 2, 2014 | 03:31 PM
mowglie's Avatar
i am having a tough time finding the wiring harness adapters to splice into existing wires for the headlights & front turn lights for my 3rd gen 97 T4R LTD.
obviously its tough to pass inspection w/o lights!
what key words do i hunt for? tried the obvious. or does someone know the actual part #s? all i need are the adapters; i already have the new lights & the existing wiring which was cut so no adapters (bought used). but at this point i'll buy whatever it takes (other than another T4R).
please help! tried all the salvage yards already.
Old Jan 3, 2014 | 03:10 AM
wyoming9's Avatar
Red face
just what happened ??
How did you end up cutting your light harness??
Perhaps someone parting out a vehicle can help you.
Pictures would be a big help
Old Jan 3, 2014 | 10:02 AM
mowglie's Avatar
thanx for your reply. sorry i wasnt better at explaining. i dont know circuitry that well, so i will try to explain what i meant above:
its not the socket inside the light assembly. its the adapter at the end of the factory wiring behind the light assembly. previous owner must have cut the wire (i bought car used). its what the light assembly plugs into to connect to the car. i have new, fully functioning light assemblies w/ bulbs & all.
does that clarify?
Old Jan 3, 2014 | 11:18 AM
wyoming9's Avatar
Red face
The plugs to plug to your head light bulbs should be part of your light harness.
the left side (Drivers) Should have A green/white stripe low Beam
red /Blue stripe High Beam
The White Green is the Ground and is common on both sides.
The Right side Blue Low beam Red /White stripe High beam
If these plugs are there unless your headlights are no longer stock they should plug in.
If they are cut off Why??
Toyota Part # 90980-11314 are the head light plugs they do come without pins.
Old Jan 3, 2014 | 12:14 PM
TheDurk's Avatar
Deleted
Old Jan 3, 2014 | 02:07 PM
mowglie's Avatar
i have no idea why the wire is cut.
just to be completely clear, is the part # you provided for the adapter at the end of the wiring going into the electrical system of the car? i dont need the adapter thats actually inside the lighting assembly, but the one thats at the end of the wiring coming from inside the car.
just trying to be crystal clear.
also is it the same part # for the headlight & the turn light wiring adapters?
Old Jan 3, 2014 | 03:02 PM
mowglie's Avatar
here is a pic of the connector in the rear of turn light assembly. i need the opposing connector that goes into the one in the image, which i can splice w/ the cut wires coming from the car.
https://drive.google.com/file/d/0B8g...it?usp=sharing
& here is the same for the headlight assembly.
thanks so much for your help!
Old Jan 4, 2014 | 03:28 AM
wyoming9's Avatar
Red face
All i can say is take your VIN in hand to your local Dealer and hope your parts people are as good as mine are.
If that will not work
Get the pins you need and wire up the lights your self .
Then solder and heat shrink the new pins .
Dielectric grease and then heat shrink over the plug and your new wires.
I have been doing this for quite awhile with these vehicles after brittle plastic plugs break.
MO transplant
Apr 23, 2023 11:58 AM
ashersullivan88yota
Jan 18, 2022 05:37 PM
smiley52
Jul 11, 2015 05:16 AM
Kalihi,HI
Jul 9, 2015 04:29 PM
colinmil
Jul 6, 2015 04:03 PM
