Axle Identity Question...
So I bought this axle off craigslist about 3 years ago. Its been sitting in my basement all this time and I've just gotten the motivation to tear it down to rebuild it.
This is a total noob project for me as I'm learning as I'm going. Watching a lot of youtube videos, 4crawler, and any how-to I can find.
But during my searches I've noticed my steering arm and knuckles look a lot different than what I've been seeing. It's suppose to be the axle out of early 80's truck, but can anyone confirm that?
This is the steering arm that bolts to the top of the knuckle-
These are the knuckles-
I can take more pictures if needed.
The 4 bolts on top of the knuckle are the trunnion brearings
Sorry - I get top and bottom confused in my head as how I'm working on it.
Mine has 4 bolts on both sides.
This video sparked most of my confusion. If you skip ahead to the 2:20 point you see him take off 2 bolts on top and not the 4 that I have.
thats a diff toyota axle in that video, there are 4 bolts on top and bottom of the knuckle like the ones you have . you will be using those 2 knuckles you have on your axle , you just wont be using any of the push pull steering, you will be using your IFS steering box with cross over steering
This is why, when you do the big brake upgrade, you use FJ60 Cruiser rotors. Because the V6 IFS rotors are only 6 hole(for the 6lugs), whereas the FJ60 rotor has 8 holes(6 for lugs, 2 for retaining bolts).
The lugs should also press into the rotor to help hold it together, and there should have been two 14mm head bolts holding the rotor to the hub.
The lugs were definitely holding everything together as well as those two bolts. One of the lugs were sheered off and made itself a real bear to get out.
