3.0 v6 tps sensor / timing. need help
Old Nov 7, 2013 | 01:34 PM
OLD RED 7903's Avatar
I have a 91 toyota v6 it runs with out the tps right now but I want to put a new one on I no how to set it with a meter but some one told me I will have to take it to a shop for the timing after I install the tps?
Old Nov 8, 2013 | 03:43 PM
mtrdud's Avatar
Fsm
Get you a factory service manual
Old Nov 8, 2013 | 04:33 PM
ksti's Avatar
Here, this will help you with your TPS, a lot of good stuff here.
http://www.4crawler.com/4x4/CheapTricks/index.shtml
P.S. If you can dial in your TPS, then you can set the timing also, pretty easy as scope103 explained.
Old Nov 8, 2013 | 04:37 PM
scope103's Avatar
... but some one told me I will have to take it to a shop for the timing after I install the tps?
You'll do better on your own w/o the shop, setting the timing. You need a timing light, of course, but the cheap $20 one will be perfect. You need to jumper TE1 to E1 on the diagnostic connector (this shuts off the add-ons to base timing; base timing is what you need to set). And the setting (degrees BTDC) are on the sticker under your hood.
some drunk guy
Aug 3, 2021 06:09 PM
Bourbonblues
Dec 15, 2017 05:43 PM
Gone Fission
Sep 22, 2015 04:51 AM
sanctfy
Sep 13, 2015 06:33 PM
EatChipsNow
Sep 9, 2015 01:25 AM
